c-thaler
2 years agoQuesta simulation hangs (nondeterministic)
I run a Questa simulation for an IP core from the command line on a Linux server. Usually, the simulation finishs successfully. But every now and then the simulation hangs. When it hangs, I can see ...
TingJiangT_Intel
Contributor
2 years agoHi there, I have tried to reproduce the issue with the file you provided but failed in the first step and shows the follow message:
Error (12007): Top-level design entity "shipment" is undefined
Seems that some files are missing.
c-thaler
2 years agoI fixed an issue with the revision name that caused the 12007 error. It should work now. I've sent you a mail with a link to our file exchange server. Please download the project from there.
