c-thaler
2 years agoQuesta simulation hangs (nondeterministic)
I run a Questa simulation for an IP core from the command line on a Linux server. Usually, the simulation finishs successfully. But every now and then the simulation hangs. When it hangs, I can see ...
TingJiangT_Intel
Contributor
2 years agoHi there, thanks for the information. Could you please help specify what steps you do when generating the script.
BTW, you may try to change the files order in the 'setting - files'. Try to move this file to the top of the list to see if it helps.
- c-thaler2 years ago
First, I do "Analysis & Synthesis" for the project. Then I go to "Tools -> Run Simulation Tool -> RTL Simulation". Then Questa comes up and fails while compiling the sources.
The file order in "Settings -> Files" is correct. The file order in the script is different than what I see in "Settings -> Files".
