c-thaler
2 years agoQuesta simulation hangs (nondeterministic)
I run a Questa simulation for an IP core from the command line on a Linux server. Usually, the simulation finishs successfully. But every now and then the simulation hangs. When it hangs, I can see ...
TingJiangT_Intel
Contributor
2 years agoHi there, I noticed that your email has been blocked. Seems it contains some files that is not allowed.
Please check the attachments. You can upload qar file after archived.
c-thaler
2 years agoThanks for he response. I'll try it again.
Unfortunately, I cannot build an qar file since it is not an Quartus project. All Questa call are made from a Shell Script. The mail was probably blocked because of this script, since it is executable.
