c-thaler
2 years agoQuesta simulation hangs (nondeterministic)
I run a Questa simulation for an IP core from the command line on a Linux server. Usually, the simulation finishs successfully. But every now and then the simulation hangs. When it hangs, I can see ...
c-thaler
2 years agoI was able to reproduce the hang up on a Windows system.
In contrast to the Linux system I was able to stop the process with Ctrl-C leading to the following output:
vish lost connection to vsim process. simulator: Unexpected EOF on RPC channel sock0000000007A71780 Kernel lost connection to front end process. ** Fatal: Exiting VSIM license process.
