djmohab2
2 years agoQuesta install not working
I have downloaded the install archive several times, un-installed, and re-installed Questa, and when I start the program, it gives me a command shell and exits out. Here is the install log. I need as...
ShengN_altera
2 years agoHi,
I tested without problem check attached screenshot. May be try download the individual file and install. Make sure using the correct license file which is Questa*-Intel® FPGA Starter Edition (License: SW-QUESTA). One more thing is make sure you're using the supported OS environment.
Sheng
