djmohab2
2 years agoQuesta install not working
I have downloaded the install archive several times, un-installed, and re-installed Questa, and when I start the program, it gives me a command shell and exits out. Here is the install log. I need as...
ShengN_altera
2 years agoMay be try to regenerate the license file and make sure correct NIC ID and computer name.
djmohab2
2 years agoI tried that, and double checked NIC and computer name. Can I get some actual assistance instead of the equivalent of turning it off and turning it back on again? The testbench I was provided and told to validate is protected and only valid for Questa. Otherwise I have to write my own testbench from scratch. This is ridiculous that I can't get an actual solution to a problem that is clearly the fault of the program's.
