23.4, and yes I have.
I have set the LM_LICENSE_FILE as a System Variable, pointing to the path in which the LR-XXXXXX_License.dat file resides.
Running Questa, I get :
Unable to checkout a license. Make sure your license file environment variable (SALT_LICENSE_SERVER, MGLS_LICENSE_FILE, LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Running the lmdiag utility gives the following:
lmutil lmdiag
lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
FlexNet diagnostics on Mon 2/19/2024 22:52
Can't fetch the requested Information!!
Kindly re-check the license file path and server details.
Please advise.
-David
