RandyL's avatar
RandyL
Icon for New Member rankNew Member
1 day ago
Questa 2 licenses?
I got a new work PC (WIndows 11) recently, so I downloaded Quartus Prime Lite 25.1.  At the time, I also included Questa Altera Edition in the download.  But I didn't try to use Questa.
Last week, I read the directions on going to the SSLC and got a license so I could start using Questa.  I got the license file, put it in a folder, and followed the directions to set it up in the Environment Variables.
I then tried to use Questa and I'm getting the error "Unable to Checkout a license. Make sure your license file environment variable (SALT_LICENSE_SERVER) is set correctly and then run 'lmutil lmdiag' to diagnose the problem."
So I dd that.  It seems that I have two license files.  One looks like it was set up automatically when I originally downloaded Quartus and Questa and the second that I got from the SSLC.
Looking in the Environment Variables, under User variables for [my_user_name], there is a variable SALT_LICENSE_FILE with a value of C:/Users/[my_user_name]/questa_lic.dat.  And under the System variables there is a variable called SALT_LICENSE_SERVER with a value of C:\[the_folder_I_setup].
I didn't set up the first environment variable.  The second one is the one I entered according to the instructions on the SSLC.  Looking at the first license file with a  text editor, I see that it is using the MAC address of my laptop's wifi adapter.  And looking at the second license file, I see that it is using the MAC address of my laptop's wired Ethernet adapter.  I think I was on wifi when I originally downloaded everything.  And I was wired when I got the license from the SSLC.
What should I do?  Which license file should it be using?  Why are there two variables and two license files?
Since the wifi and wired connections on any computer always have different MAC addresses, is it not possible to use Questa with both?  In other words will I always have to be using one of these connections and not the other?  That would stink.
1 Reply
  • ShengN_altera's avatar
    ShengN_altera
    Please use SALT_LICENSE_SERVER and delete the SALT_LICENSE_FILE.
    Please use enabled and available mac address
