King22
4 months agoQuartusPro25.3 STA Error
I use QuartusPro25.3 , Device is AGILEX 7 , I found it often report error when in the "retiming " stage, Sometime I just modify my design to add some debug signal , and it report error ,error massa...
King22
4 months agoSorry , I can't attach my design ,sometimes just change some debug signal and it report error ,
modify debug signal like below ( F-tile RX related signal )
wire [7:0] DBGO_FPGA_RX_06H = {
//rx_set_locktodata[1],edp_pll_lock[1],rx_is_lockedtodata_sys1,rx_is_lockedtoref_sys1, //4 bit use this error
rx_ready_sys1,rx_ready_sys0,rx_is_lockedtodata_sys1,rx_set_locktodata[0], //4 bit use this ok
rx_is_lockedtodata_sys0,rx_reset_ack_sys0,rx_reset_sys0,edp_reset_cdr[0]} ;
should I update QuatrusPro to 26.1
KennyT_altera
4 months agoIs there further queries? If no, we shall close the thread.
