QuartusPro25.3 STA Error
Sorry , I can't attach my design ,sometimes just change some debug signal and it report error ,
modify debug signal like below ( F-tile RX related signal )
wire [7:0] DBGO_FPGA_RX_06H = {
//rx_set_locktodata[1],edp_pll_lock[1],rx_is_lockedtodata_sys1,rx_is_lockedtoref_sys1, //4 bit use this error
rx_ready_sys1,rx_ready_sys0,rx_is_lockedtodata_sys1,rx_set_locktodata[0], //4 bit use this ok
rx_is_lockedtodata_sys0,rx_reset_ack_sys0,rx_reset_sys0,edp_reset_cdr[0]} ;
should I update QuatrusPro to 26.1
- KennyT_altera4 months ago
Without the design, it will be hard to root cause the problem. Is that fine that you attached the design privately with NDA sign?
Is there further queries? If no, we shall close the thread.
- KennyT_altera3 months ago
closing the thread since there are no further update.
