18 years agoQuartus VHDL compiler returns error 10818
Hello.
I am trying to compile some VHDL code in Quartus II and the compiler returns me a bunch of errors: Warning (10631): VHDL Process Statement warning at AddrDecoder.vhd(20): inferring latch(es) for signal or variable "dataout_s", which holds its previous value in one or more paths through the process Error (10818): Can't infer register for "dataout[0]" at AddrDecoder.vhd(61) becuse it does not hold its value outside the clock edge I tryed to compile the same source in modelsim and it worked fine. Althought i can make a schematic file or write it in AHDL and it will work as VHDL code. So i cannot understand why the VHDL file is not syntesizable. Maybe someone can help me with it. The code is: library IEEE; use IEEE.std_logic_1164.all; entity addrdecoder is port( inbit : in std_logic; clk : in std_logic; sel : in std_logic; dataout : out std_logic_vector(7 downto 0); complete : out std_logic; flat: in std_logic_vector(2 downto 0)); end addrdecoder; architecture arc_addrdecoder of addrdecoder is signal dataout_s : std_logic_vector(7 downto 0); signal done: std_logic; signal currbit : std_logic_vector(2 downto 0); begin process(sel,clk,done) begin if(sel='1') then dataout<=x"0f"; dataout_s<=x"0f"; done<='0'; currbit<="000"; else if(clk'event and clk='1' and done='0') then case currbit is when "000" => dataout_s(7)<=inbit; currbit<="001"; when "001" => dataout_s(6)<=inbit; currbit<="010"; when "010" => dataout_s(5)<=inbit; currbit<="011"; when "011" => dataout_s(4)<=inbit; currbit<="100"; when "100" => dataout_s(3)<=inbit; currbit<="101"; when "101" => dataout_s(2)<=inbit; currbit<="110"; when "110" => dataout_s(1)<=inbit; currbit<="111"; when "111" => currbit<="111"; done<='1'; when others => dataout_s<=x"FF"; done<='0'; currbit<="000"; [/INDENT] end case;[/INDENT] end if;[/INDENT] end if; if(done'event and done='1') then if(flat=dataout_s(6 downto 4)) then dataout<=dataout_s; dataout(0)<=inbit; end if;[/INDENT] end if; end process; complete<=done; [/INDENT]end arc_addrdecoder; configuration cfg_addrdecoder of addrdecoder is for arc_addrdecoder end for; end cfg_addrdecoder; The code should do the following: 1) the sel pin is reset pin. when it is high the output is x"0f" 2) when the sel is going low the chip will get 8 pulses of the clock pushing "inbit" from MSB to LSB into the register "dataout_s" 3) after 8 clk pulses the code will compare the pushed data, bits 4 to 6 ,to an external address "flat" and if it is equal then the pushed data will be transfered to the dataout pins and complete signal will become high. Thanks all.
