18 years agoHere is the VHDL code,i have make it OK!
It works! library IEEE; use IEEE.std_logic_1164.all; entity addrdecoder is port( inbit : in std_logic; clk : in std_logic; sel : in std_logic; dataout : out std_logic_vector(7 downto 0); complete : out std_logic; flat: in std_logic_vector(2 downto 0) ); end addrdecoder; architecture arc_addrdecoder of addrdecoder is signal dataout_s : std_logic_vector(7 downto 0); signal done: std_logic; signal currbit : std_logic_vector(2 downto 0); begin process(sel,clk,done) begin if(sel='1') then dataout<=x"0f"; dataout_s<=x"0f"; done<='0'; currbit<="000"; elsif(clk'event and clk='1' ) then if done='0' then case currbit is when "000" => dataout_s(7)<=inbit; currbit<="001"; when "001" => dataout_s(6)<=inbit; currbit<="010"; when "010" => dataout_s(5)<=inbit; currbit<="011"; when "011" => dataout_s(4)<=inbit; currbit<="100"; when "100" => dataout_s(3)<=inbit; currbit<="101"; when "101" => dataout_s(2)<=inbit; currbit<="110"; when "110" => dataout_s(1)<=inbit; currbit<="111"; when "111" => currbit<="111"; done<='1'; when others => dataout_s<=x"FF"; done<='0'; currbit<="000"; end case; if(done'event and done='1') then if(flat=dataout_s(6 downto 4)) then dataout<=dataout_s; dataout(0)<=inbit; end if; end if; end if; end if; end process; complete<=done; end arc_addrdecoder; configuration cfg_addrdecoder of addrdecoder is for arc_addrdecoder end for; end cfg_addrdecoder;
