quartus system console font too small, windows 11, monitors 2496 / 1664
- 3 years ago
Let me know if there is any update at your end.
Yes @SyafieqS
It seems general "feature" of the Intel Quartus software, that unlike other windows programs, For each resolution monitor, one has to change the font size in the program .
As I'm moving between laptop, multi monitor and large monitors it is certainly noticeable.
Im not a sw engineer but I wonder why its just the intel code ?
I've not been using Altera / Intel code for about a decade, been on other fpga families, and this font bug is very noticable Intel related.
Thank you
Hi John!
I had the same Issue, I solved it going to the install folder, in my case: "intelFPGA_pro\22.2\syscon\bin"
Next doing the instructions on the following link for the file "system-console.exe":
I used System (Enhanced) on the last options, after that you can open the system-console from quartus or what I'm going to do is also create a shortcut from here so it's a little faster than opening quartus and then system console.
Hope this helps.
Mauricio
