quartus system console font too small, windows 11, monitors 2496 / 1664
- 3 years ago
Let me know if there is any update at your end.
Does this issue appear to other monitor as well?
If that's the case, you have to manually change the font as mentioned as workaround.
Yes @SyafieqS
It seems general "feature" of the Intel Quartus software, that unlike other windows programs, For each resolution monitor, one has to change the font size in the program .
As I'm moving between laptop, multi monitor and large monitors it is certainly noticeable.
Im not a sw engineer but I wonder why its just the intel code ?
I've not been using Altera / Intel code for about a decade, been on other fpga families, and this font bug is very noticable Intel related.
Thank you
- MauricioM3 years ago
Hi John!
I had the same Issue, I solved it going to the install folder, in my case: "intelFPGA_pro\22.2\syscon\bin"
Next doing the instructions on the following link for the file "system-console.exe":
I used System (Enhanced) on the last options, after that you can open the system-console from quartus or what I'm going to do is also create a shortcut from here so it's a little faster than opening quartus and then system console.
Hope this helps.
Mauricio
