quartus_sign fails to generate signed ccert
Following Intel Agilex® 7 Device Security User Guide for AES Root Key Provisioning, the quartus_sign command fails with Error (20354) but this is no help. Executing the following two commands fails on the second command - all the necessary input files have been generated successfully:
## Create an unsigned AES compact certificate for the desired AES root key storage location:
quartus_pfg --ccert -o ccert_type=EFUSE_WRAPPED_AES_KEY -o password=passphrase.txt -o qek_file=aes_root.qek unsigned_efuse1.ccert
Hi @Farabi , I was able to get help from Intel via our FAE. Basically the answer was the permission settings (should have been 0x40) which are part of the "Security Methodology for Intel FPGAs and Structured ASICs User Guide". However, this document is restricted. But for others reading this post, the correct settings were actually part of the " Intel Agilex® 7 Device Security User Guide", Page 33.
I will close this case. Thank you.
- Farabi_Altera
Sorry for late reply. I am still checking with our internal team to get the details of this error.
I will get back to you asap when I have the information.
regards,
Farabi
- grspbr
I'm looking forward to your response. We are quite stalled on this. Thanks!
- grspbr
By the way, there is a case number for this that has been opened by our FAE: 00885849
- grspbr
- Farabi_Altera
KDB(Knowledge Database) has been established to share the solution to more users. I am transferring this case to community back to open access for community support.
