RZhen11's avatar
RZhen11
6 years ago
Quartus project tasks completed check mark missing after reopen (18.1 std edition)
The project used to keep task completed check mark so I can tell the source has not changed.
Since I started adding .stp file into the project. Every time reopen the project, there is no "green" check mark at any of the task .
It's not critical, but will nice to know what happened.
  • sstrell's avatar
    sstrell
    If you make a change to the project, like adding a .stp file or making a change to any file, like the .stp file, the indicator goes away because that means you have to recompile the project. The current compilation results no longer match the project, requiring a recompile.
    #iwork4intel
    • RZhen11's avatar
      RZhen11
      I understand when project source has change, the project goes out-of-date.
      But my situation is there is no change at all. What I meant in the original post is, the project seems changed after I started adding .stp file.
      There are other weirdness, for example, I can't do signalTap at all.
      • sstrell's avatar
        sstrell
        Adding Signal Tap is a change to the project that requires recompilation as well. It's not just source code changes that do it.
        If you don't recompile, that would explain why Signal Tap isn't working as well. Check the Signal Tap settings in the Settings dialog box are pointing to your .stp file and then recompile.
        #iwork4intel
