Quartus project tasks completed check mark missing after reopen (18.1 std edition)
If you make a change to the project, like adding a .stp file or making a change to any file, like the .stp file, the indicator goes away because that means you have to recompile the project. The current compilation results no longer match the project, requiring a recompile.
#iwork4intel
- RZhen116 years ago
I understand when project source has change, the project goes out-of-date.
But my situation is there is no change at all. What I meant in the original post is, the project seems changed after I started adding .stp file.
There are other weirdness, for example, I can't do signalTap at all.
- sstrell6 years ago
Adding Signal Tap is a change to the project that requires recompilation as well. It's not just source code changes that do it.
If you don't recompile, that would explain why Signal Tap isn't working as well. Check the Signal Tap settings in the Settings dialog box are pointing to your .stp file and then recompile.
#iwork4intel
Thanks for prompt reply. I was not being clear.
I understand whenever I add or make change to .stp, the project requires recompile.
But my current project became out-of-date when I had done no change, .stp file was added and the whole project was compiled already. When I open the .top, I can't connect even after programming (programmed in side SignalTap program function) and there is no other programmer/Quartus opened.
The whole situation starts days ago, when I started adding .stp file.
I will try your approach of delete .db, ** folders
