17 years ago
Quartus problem in Megawizard memory
While attempting to generate a dual-port memory, I receive the following message:
"Error: Symbolic name "RAM_MAX_ADDRESS_WIDTH" is used but not defined"
.. when the 'altsyncram.tdf' is elaborated.
This has happened before, but only after the files were EDITED, not CREATED: i.e., it worked once, then no more after it was modified.
This particular case won't work even after I re-enter the whole thing under a different name.
What might be wrong?
Wade Hassler
    --- Quote Start ---
    Wade Hassler
    --- Quote End ---
    Hi Wadw,
    which Quartus Version and FPGA are you using ?
    Thanks for the reply. I'm using Quartus 8.1 and an EP3c8Q208C8
    Wade
    --- Quote Start ---
    Wade
    --- Quote End ---
    Hi Wade,
    I did not find your device in Quartus . Type mismatch ??? I assume you are using a Cyclone III device ?
    I generated a Dual-ported Ram with the Megawizard without any poblems. How did you generate your Ram ? With the Meagwizard also ? What are your settings ?
