17 years ago --- Quote Start --- While attempting to generate a dual-port memory, I receive the following message: "Error: Symbolic name "RAM_MAX_ADDRESS_WIDTH" is used but not defined" .. when the 'altsyncram.tdf' is elaborated. This has happened before, but only after the files were EDITED, not CREATED: i.e., it worked once, then no more after it was modified. This particular case won't work even after I re-enter the whole thing under a different name. What might be wrong? Wade Hassler --- Quote End --- Hi Wadw, which Quartus Version and FPGA are you using ?
