Altera_ForumHonored Contributor17 years agoQuartus problem in Megawizard memory While attempting to generate a dual-port memory, I receive the following message: "Error: Symbolic name "RAM_MAX_ADDRESS_WIDTH" is used but not defined" .. when the 'altsyncram.tdf' is elabor...Show More
Altera_ForumHonored Contributor17 years agoThanks for the reply. I'm using Quartus 8.1 and an EP3c8Q208C8 Wade
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
