quartus pro 25.3 bug?
This is more related to the SI issue. You can use a stp to check if LTSSM is failed and where it fails. You should run the PCIe test only when the link is stable.
Rong
- zjj1 month ago
we already use stp to check ltssm status and ltssm status is in L0/L1 that belong to normal state.
however, we find the Avalon-ST TX interface of the PCIe hard IP reveals continuous toggling on both the hvld and dvalid signals. and we have verified that no traffic is being sourced to this interface,
- RongY_altera1 month ago
Contributor
I tested R-Tile PCIe Gen5 1x16 with a AVST PIO design on Q25.3.1 Pro. My stp doesn't see any toggling on tx_stX_hvalid and rx_stX_dvalid signals.
On the problem board, I suggest you to test a PCIe only design first. Pls check your qsf to make sure PCIe related pins are correctly constrained before compilation. After system boots up, confirm the LTSSM is stable, i.e. not toggling, and link speed & width is correct. Before the application runs, the hvalid and dvalid signals are expected to stay LOW.
Rong
- zjj1 month ago
accorind to r-tile avalon streaming IP user guide, the slow_clk is sync to coreclkout_hip. But during test on-board, we find that the slow_clk and coreclkout_hip may lost sync sometimes. so how to debug further?
