8 years agoQuartus Prime Standard Edition v17.0 Error: add_fileset_file: No such file
I'm facing error in Qsys while generating NIOS system with "create simulation model" = either verilog or vhdl, no error if "create simulation model" = NONE. Does anyone know what is causing this error? Thanks. https://alteraforum.com/forum/attachment.php?attachmentid=14441&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14442&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14443&stc=1 Error: add_fileset_file: No such file /tmp/alt7491_7829365739350634514.dir/0006_cpu_gen/simgen_tmp_0 while executing "add_fileset_file "$file_name" OTHER PATH "$my_file"" (procedure "sub_add_generated_files" line 51) invoked from within "sub_add_generated_files "$NAME" "$output_directory" "$rtl_ext" "$simgen" "$plainTEXTfound"" (procedure "generate_with_plaintext" line 6) invoked from within "generate_with_plaintext "$NAME" "$rtl_ext" "$simgen"" (procedure "sub_sim_verilog" line 5) invoked from within "sub_sim_verilog nios_nios2_gen2_0_cpu" Error: Generation stopped, 33 or more modules remaining Error: qsys-generate failed with exit code 1: 2 Errors, 0 Warnings6 Replies
Are you using the fast version of the processor? Do you have a license for the fast version?
--- Quote Start --- Are you using the fast version of the processor? Do you have a license for the fast version? --- Quote End --- yes, I'm using NIOS II/f, Qsys is able to generate synthesis files but not simulation files, seems not license issue. And Qsys Pro can generate both the simulation and synthesis files. Thanks. - Altera_Forum
Can you try following.
1. Try generating the testbench for same project and see if you face similar Error ? Qsys menu Generate > Generate Testbench System 2. Use the NIOs system from AN351 and see if you can generate the simulation file https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-simulating-niosii.html 3. Also try newer version of Quartus Prime 17.1 ? Best Regards, arslanusman2003 (This message was posted on behalf of Intel Corporation) - Altera_Forum
1. I tried "Generate Testbench System", as long as "Create Simulation Model" is Verilog or VHDL, generation failed. 2. Same failure. 3. It will take some time to install 17.1, I have tried v16 with same error. Quartus II v13.1 has no issue. Thanks. - Altera_Forum
Hi Terry,
It is working fine with Quartus prime Standard Edition. Recheck steps and license. OR reinstall the quartus. Refer attached image in word document Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Hi Anand,
I will try v17.1 and get back. Thanks for your support.
