8 years agoQuartus Prime Standard Edition v17.0 Error: add_fileset_file: No such file
Hi, I'm facing error in Qsys while generating NIOS system with "create simulation model" = either verilog or vhdl, no error if "create simulation model" = NONE. Does anyone know what is causi...
8 years ago --- Quote Start --- Are you using the fast version of the processor? Do you have a license for the fast version? --- Quote End --- yes, I'm using NIOS II/f, Qsys is able to generate synthesis files but not simulation files, seems not license issue. And Qsys Pro can generate both the simulation and synthesis files. Thanks.
