8 years agoQuartus Prime Standard Edition v17.0 Error: add_fileset_file: No such file
Hi, I'm facing error in Qsys while generating NIOS system with "create simulation model" = either verilog or vhdl, no error if "create simulation model" = NONE. Does anyone know what is causi...
8 years agoHi,
1. I tried "Generate Testbench System", as long as "Create Simulation Model" is Verilog or VHDL, generation failed. 2. Same failure. 3. It will take some time to install 17.1, I have tried v16 with same error. Quartus II v13.1 has no issue. Thanks.
