Quartus prime problem report - active serial SST26VF032B
I have this message when in want to programming my board:
Problem Details Error: Internal Error: Sub-system: PGME, File: /quartus/pgm/pgme/pgme_engine.cpp, Line: 4555 count >= static_cast<DWORD>(device_chain->size()) Stack Trace: 0x55ee1: PGME_PROGRAMMER::get_device_chain_with_dummy_jtag_bit + 0x161 (pgm_pgme) 0x3fe8f: PGME_PROGRAMMER::engage + 0x288f (pgm_pgme) 0x8b715: PGMWQ_PROGRAMMING_THREAD::run + 0x25 (pgm_pgmwq) 0x2c760: QThread::start + 0x3e0 (Qt5Core) 0x1257c: BaseThreadInitThunk + 0x1c (KERNEL32) 0x5af27: RtlUserThreadStart + 0x27 (ntdll) End-trace Quartus Prime Version 22.1std.1 Build 917 02/14/2023 SC Lite Edition Executable: quartus Comment: None System Information Platform: windows64 OS name: Windows 10 OS version: 10.0 Quartus Prime Information Address bits: 64 Version: 22.1std.1 Build: 917 Edition: Lite Edition
I'm not sure if i made the good manipulation.
I tried to flash the memory connectited to my 10CL040YF.
The memory is the SST26VF032B.
But this memory are not in the list sor i'm not sur if i've choos the good ...
Some help please .
- Farabi_Altera
Please refer to supported flash devices here : https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-guidance/configuration-support.html
The flash you are using is not supported.
regards,
Farabi
- FvM
the linked device support list is hardly an exclusive specification, just tells which devices are known to work.
It's not clear which configuration device settings are you using in Programming File Converter tool. Do you use the "new device" feature to define correct programming commands for SST26VF032B?
Frank - LOPEZ_olivier
My request was made 3 months ago.
Since then I have succeeded in creating a new device to make a .jic which I load into my FPGA.
- FvM
Very good, that's what I expected.
"flash isn't supported" should be rephrased "there's no predefined support, need to edit configuration"
