LOPEZ_olivier
2 years agoQuartus prime problem report - active serial SST26VF032B
Hello, I have this message when in want to programming my board: Problem Details
Error:
Internal Error: Sub-system: PGME, File: /quartus/pgm/pgme/pgme_engine.cpp, Line: 4555
count >= static_cast<...
FvM
1 year agoHi,
the linked device support list is hardly an exclusive specification, just tells which devices are known to work.
It's not clear which configuration device settings are you using in Programming File Converter tool. Do you use the "new device" feature to define correct programming commands for SST26VF032B?
Frank
