Quartus Prime Lite Edition - Setting File Reference Manual &&& weak pull-up
- 1 year ago
Sorry,
this should be a valid link. Copied from site search. Intel could spend quite a bit more effort to maintain website integrity. I'll post my latest copy, not necessarily current version.
FrankP.S.: There's only one setting for unused pins. If you want other initialization of some pins, they must be defined as ports in your design top and assigned in pin planner to pin locations. Initialization of output to '1' can done in port definition, weak pull-up feature of input or tri-stated inout in pin planner or assignment editor.
Thanks frank.
It helped me a lot.
However, I can't download the PDF file from the link provided.
If you know of a site where I can download it, please let me know.
An additional question is,
I want to make some unused pins internally pull-up and the rest high output.
What should I do in this case?
Regrads
Daejin
Sorry,
Frank
- DaeJin1 year ago
Dear Frank,
Thank you so much for your detailed and quick reply.
Have a Merry Christmas.
Daejin.
