Quartus Prime 25.1 Lite - Display Issues
- 8 months ago
The GUI issue where the text appears to overlap for the ALTPLL is a known problem that has existed for some time.
You can either use a Linux OS or instantiate it using HDL, as mentioned in another forum post shared by FvM.
Unfortunately, the fix is still in progress because it involves a legacy IP.
Richard Tan
Quartus V25.1 corrupted altpll GUI is a known bug, we are yet waiting for a fix. See e.g. ALT PLL GUI MESSDED UP ON INVOCATION | Altera Community
Regarding Prime text editor Verilog syntax highlighting, I see change starting with Quartus Prime Std. V21.1 (don't have presently 20.1 installed) and definitely not in V19.1. I wonder why it was done, is it intentional at all? I agree there should be fallback or configuration option.
Frank
- Arno-NL8 months ago
Thanks for your comment. I looked in this forum and didn't find anything about the GUI garble in this Quartus Prime sub forum. Am I right you are using the standard/pro version of Quartus? I know the standard version is now at 25.3 and I have no idea whether this GUI bug has been fixed in that version. Maybe you can tell? As for a fix for the Lite version, yeah I'll have to wait. I'm not hinging on PLL configuration as I could do that with an older version. Thanks once more,
Arno.
- sstrell8 months ago
Standard and Lite are basically the same code base and they are at 25.1, not 25.3. The link Frank provided goes into this, and there have been a number of other posts about this recently.
