10 years agoQuartus Illegal configuration of I/O primitive inst: port ERROR
All,
Schematic entry: I am not seeing what I am doing wrong here. I have a primitive ALT_IOBUF tied to a primitive BIDIR pin. The control input is tied to 1 pin (master) The OUTPUT is tied to 1 and only 1 BIDIR pin (nc5) The OUT Going buffer is tied to 1 net (nc[5]) The IN Coming buffer is tied to 1 net (ncin[5]) Then I get the error. What am I doing wrong. Quartus 9.0 (yeah I know there are newer free versions, but this has been working for me) Windows10: so far all my other designs have not had any issues (see attachment) Keith2 Replies
I assume this is just part of your design, and that master, nc[5], and ncin[5] are connected somewhere. I tried to duplicate your schematic in quartus 13.0, and I get this error: Error (17037): Illegal configuration of I/O primitive inst: port "io" should be directly connected to a single bidir pin. But, I also get this warning: Warning (275080): Converted elements in bus name "nc" using legacy naming rules. Make any assignments on the new names, not on the original names. Warning (275081): Converted element name(s) from "nc[5]" to "nc5" I think Quartus renames any bus net name such as bus[x] to busx. So you end up with both the input and i/o pin on ALT_IOBUF connected to net nc5. I tried renaming the net nc[5] to ncout[5], and then the error went away for me. - Altera_Forum
Thanks for the info. I WAS able to get that module to work.... but..... now when I use that module in the rest of my design, I get the same error again....
I did the work around and now "master" controls MUXs for producing the clk waveforms or "not master" using waveforms derived from another IC. I have also ran into the problem using net naming issues. Such as the nc5 and nc4 are nets in a bus nc[5..0], but I was informed that the the individual net names have to be established as nc[5] and nc[4]. So I just label them to where I don't get an error or warning. (one project I use labeling as nc[X] and the other I use labeling as ncX I think I am making it work. Thanks again, Keith
