10 years agoQuartus Illegal configuration of I/O primitive inst: port ERROR
All, Schematic entry: I am not seeing what I am doing wrong here. I have a primitive ALT_IOBUF tied to a primitive BIDIR pin. The control input is tied to 1 pin (master) The OU...
10 years agoHi,
I assume this is just part of your design, and that master, nc[5], and ncin[5] are connected somewhere. I tried to duplicate your schematic in quartus 13.0, and I get this error: Error (17037): Illegal configuration of I/O primitive inst: port "io" should be directly connected to a single bidir pin. But, I also get this warning: Warning (275080): Converted elements in bus name "nc" using legacy naming rules. Make any assignments on the new names, not on the original names. Warning (275081): Converted element name(s) from "nc[5]" to "nc5" I think Quartus renames any bus net name such as bus[x] to busx. So you end up with both the input and i/o pin on ALT_IOBUF connected to net nc5. I tried renaming the net nc[5] to ncout[5], and then the error went away for me.
