14 years ago
Quartus II web edition licensing
I have installed the Quartus II v11 sp2 and I received a license as I requested.
ANd, I followed the steps to map the license file from the Quartus. But still, Quartus says that it requires the license file, which I already did, and so am not able to do full compilation.
My machine is running on a Win XP 32 bit OS.
My network is restricted and hence I have to use the proxy network setting to connect to internet.
I am sure and entered the proxy address and the port in the proxy setting, I am not sure about the username/psswrd, what exactly is this asking for?
Does this problem of internet connection bars me from validating the license ? and so I am having problem withe full compilation?
Please help.
    --- Quote Start ---
    Does Quartus II v11 sp1 (web edition) supported by Win 7 (64 bit)?
    --- Quote End ---
    http://www.altera.com/download/os-support/oss-index.html
    Footnote 1 implies yes, but then footnote 2 says no :)
    Though technically it says
    "The Quartus II Web Edition software is supported on the 32-bit versions of the operating systems."
    Which doesn't mean it won't work, it just means if you have a problem, you cannot file a service request and expect to get any help.
    Just install Virtual PC or VirtualBox+WindowsXP and install it there.
    Cheers,
    Dave
    Dave,
    I went back to basics- I tried to create a new small project and it compiled !!! :)
    So, the problem, as you pointed out in beginning- that my existing project ( someone else was working on it); and am taking it over- might have used some paid or licensed IP.
    So, figured out the mystery.
    I can go back find that IPs (separate topic though)
    Thanks a lot for being here replying my questions.
    rrk
    --- Quote Start ---
    --- Quote End ---
    No, if you read the error message, it was probably because you were trying to use a Cyclone device. Go and look at the device settings in the non-working project and in the working project. See if one is a Cyclone I device and the other is a Cyclone II/III/IV device.
    --- Quote Start ---
    --- Quote End ---
    No, you have just got a different result. You still need to find where you went wrong :)
    --- Quote Start ---
    --- Quote End ---
    You're welcome.
    Cheers,
    Dave
    PS. The Cyclone I vs Cyclone II/III/IV comment came about from another thread that appears to have the same error message:
    http://www.alteraforum.com/forum/showthread.php?t=35333
    Error (20005): A license file is required to enable compilation of your design for the Cyclone family of devices
    Actually,
    the issue that the particular project doesnt compile with v11 sp1 (web edition) and asks for license, may or may not be because it has license IP or paid IP.
    This particular project was built using version 7.0.
    Is it a straightforward way to just open this old project with v11 sp1 and say compile- does this require license?
    If this project has any payable IP used earlier, how can I check those IPs now?
    rrk
    --- Quote Start ---
    --- Quote End ---
    Which device was the project targeting? If the device is too old, 11.1sp1 will not support it. The error message implies you are trying to compile for the Cyclone series, of which Cyclone I devices are not supported.
    --- Quote Start ---
    --- Quote End ---
    Look at the code. The tool should tell you which IP cores require a license.
    Cheers,
    Dave
    Hey Dave,
    You are absolutely correct.
    The project which was built using ver 7.0 was built with Cyclone family (cyclone I).
    Some how I managed to install the ver 7.0 and it compiles just fine with it and I verified this info.
    Now, the next task is to bring this project up to the current family say Cyclone II, so that I can use the newer version of Quartus.
    Do you foresee to redo the project with new device or is there any way out? Please advise
    rrk
    --- Quote Start ---
    --- Quote End ---
    Usually a project targets a specific board. If your board has a Cyclone I device, then you need to use a version of Quartus that supports Cyclone I. I'm not sure when they dropped support for Cyclone I in the web edition, but its most likely the last 10.x version.
    If your design is really just to learn VHDL and it doesn't really target any hardware, then you can just create a new project, import the VHDL and .SDC (timing constraints) file and synthesize for a Cyclone IV.
    Cheers,
    Dave
    Hi all,
    I am using quartus 9.1 webedition. I am trying to read a text file and trying to simulate and see the results in the quartus simulator. I dont have any errors. But still it is not reading. The same program works well with modelsim. So quartus simulator doesn't support this feature.
    --- Quote Start ---
    --- Quote End ---
    The newer versions of Quartus do not have a simulator. The Altera developers realized they had better things to do than try to reproduce Modelsim.
    Use Modelsim for simulation, and Quartus for synthesis.
    Cheers,
    Dave
