14 years ago --- Quote Start --- This particular project was built using version 7.0. --- Quote End --- Which device was the project targeting? If the device is too old, 11.1sp1 will not support it. The error message implies you are trying to compile for the Cyclone series, of which Cyclone I devices are not supported. --- Quote Start --- If this project has any payable IP used earlier, how can I check those IPs now? --- Quote End --- Look at the code. The tool should tell you which IP cores require a license. Cheers, Dave
