Quartus II Synthesis - System Memory Issues for Large Stratix 10 Design
Hi @CADAMS,
Good day, just following up on the previous clarification.
By any chances did you managed to look into the it?
Best Wishes
BB
Thanks for getting back to me. Sorry for slow reply.
I'm not sure what you mean by 'trigger', the Verilog generate-for loop instantiates parallel instances of the IP core. If the for loop is large, then during compilation the memory usage is untenable.
SOMEBIGNUMBER is approximately 200. I cannot share the exact HLS code, but it is essentially a cumulative sum across 128 inputs. Here is some psuedo code:
float myHlsCore(16bit integer stream_in)
static float runSum = 0;
for c=1:128
runSum+= stream_in[c];
return runSum;
We have partially solved the issue by creating a very large swap file on the system (~500GB), but this is not a realistic solution as memory access is extremely slow on the swap.
Now the compilation process fails, saying the design cannot be routed, despite resource usage being less than 60%. It is a slightly different issue, but I think they are related, and I do not think that the swap file is a good solution to the original problem either.
Chris
