14 years agoQuartus II crashing in Help menus
I'm receiving the following message when I try to select something from the Help menu which is not a good thing considering I'm a beginner: Internal Error: Sub-system: THR, File: /quartus/ccl/thr/thr_process.c, Line: 445 Failed to create process! Stack Trace: 0x1dbe: _thr_internal_error + 0x1e (ccl_thr) 0x15e4: _thr_process_create_and_save_job + 0x404 (ccl_thr) 0x1b44: _thr_process_create + 0x24 (ccl_thr) 0x53c5: _ictq_dyn_go_to_optional_or_web_help_or_spr_url + 0x225 (sys_ictq) 0x4a61: ictq_locate_to_web_page + 0x141 (sys_ictq) 0x6519: _ictq_dyn_locate_to_web_page_based_on_url + 0x39 (sys_ictq) 0x3baa: hlpq_display_topic + 0x48a (sys_hlpq) 0x3e4a: _hlpq_dyn_show_enumerated_topic_impl + 0x20a (sys_hlpq) 0x4603: QUI_HELP_MENU::tutorial_action + 0x63 (SYS_QUI) 0x90cc: QUI_HELP_MENU::qt_metacall + 0xbc (SYS_QUI) 0xe0eae: QMetaObject::metacall + 0x3e (QtCore4) 0xc57d: QAction::activate + 0xcd (QtGui4) 0x348a28: QMenu::findIdForAction + 0x288 (QtGui4) 0x34e500: QMenu::internalDelayedPopup + 0x680 (QtGui4) End-trace Quartus II 32-bit Version 11.1 Build 216 11/23/2011 SJ Web Edition Service Pack Installed: 1 When I dismiss the error dialog, Quartus II crashes. Note, I'm running Windows 7 SP 1 on a MacBook. Thanks!
