Jens's avatar
Jens
25 days ago
Quartus did not start
Since the switch to European Summer Time we cannot start Quartus Prime 2025 in Windows 11.
Error Message:
The application could not be started correctly (0xc0000142)
What could be the reason for that?
Jens
  • KennyT_altera's avatar
    KennyT_altera
    I have included all my screenshots here. Could you also include the relevant screenshots you have so that I can compare and provide internal feedback?
    Please also include information about your antivirus and firewall.
  • GBraj's avatar
    GBraj
    Hi everybody,
    I’m experiencing the same issue here. The machine is running multiple versions of Quartus Prime Pro (23.4, 24.1, 24.3, and 25.3), all patched in January due to the infamous date/time issue.
    The system is running Windows 11 25H2, and no software or driver changes have been made in the last 30 days. Windows localization is set to Italian.
    The Linux version of Quartus Pro works fine, fortunately.
    About two years ago, I had a similar problem and opened a post here: https://community.altera.com/discussions/nios-system/niosv-shell-and-riscfree-dont-start---application-error/297403
    At that time, however, I was able to solve the issue simply by rebooting the PC, also because the team was not able to reproduce the error. I've tried to reinstall Visual C++ redistributables but with no luck.
    • Jens's avatar
      Jens
      Hi billmax,
      yes, we use Sophos. We will check the behavior without running Sophos when the admins allow us that.
        KennyT_altera
        Good to know that both of you using Sophos, do let us know the result after you disable/uninstall it.
        Also, can you list down all the software that is running behind the machine,  if the above does not solve.
    KennyT_altera
    We understand how disruptive the “The application was unable to start correctly (0xc0000142)” error can be.
    We have attempted to replicate the problem in our in-house environment, but so far we have been unable to duplicate the issue. As a result, your assistance with the following debugging steps is essential to help us narrow down the root cause and resolve this matter as efficiently as possible.
    Debugging Steps:
    Reregister All DLL Files
    • Open Command Prompt as Administrator (search for cmd, right-click, select "Run as administrator").
    • Run the following command and press Enter:for %i in (%windir%\system32\*.dll) do regsvr32.exe /s %i
    • Then run:for %i in (%windir%\system32\*.ocx) do regsvr32.exe /s %i
    • Close Command Prompt.
    Set Correct System Locale
    • Press Windows + R, enter intl.cpl, and click OK.
    • In the Administrative tab, click Change system locale... and select the English region (e.g., English (United States)).
    • Click OK and restart your computer.
    Run Quartus as Administrator
    • Right-click the Quartus icon, select Properties.
    • Under the Compatibility tab, check Run this program as an administrator.
    • Click Apply and OK.
    Reset LoadAppInit_DLLs Registry Value
    • Press Windows + R, type regedit, and press OK.
    • Navigate to:
      HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows
    • Double-click LoadAppInit_DLLs and set the value to 0.
    • Click OK and restart your PC.
    Install Latest Microsoft C++, .NET Framework, and DirectX
    Use Process Monitor (Advanced)
    • Download Process Monitor.
    • Run Procmon.exe, start Quartus, and look for any “NAME NOT FOUND” or “PATH NOT FOUND” errors indicating missing DLLs.
    Update Graphics Drivers
    • Visit your graphics card vendor’s website (e.g., NVIDIA Driver Downloads), download and install the latest driver for your GPU, and restart your system.
    Next Steps:
    Please proceed through these steps, restarting your system after each major change. If the error persists after completing these steps, kindly let us know which steps you have tried and any observations or error messages you encounter. This will help us further isolate the issue and recommend the next course of action.
    We greatly appreciate your cooperation and patience
  • Jens's avatar
    Jens
    It seems Sophos isn't the problem. Our administrator has partially disabled Sophos's access and Quartus didn't start.
    We have followed the debugging steps suggested by KennyT and the process monitor is showing numerous issues with “NAME NOT FOUND”.
    • syoma's avatar
      syoma
      Hi Jens
      We have just tested with Sophos Endpoint Agent settings and this is actually it. If you use Override Sophos Central Policy for up to 4 hours to troubleshoot and uncheck Malicious Behavior Detection ("Erkennung von schädlichem Verhalten") option in Runtime Protection - then Quartus is starting normally. So we are pretty sure it has something to do with it.
      Could you please check on your side this again?
        KennyT_altera
        Thank you for your feedback, we will also investigate this and get back to you.
  • billmax's avatar
    billmax
    The attached log is from last week before trying any of the new steps. There are plenty of "NAME NOT FOUND" but for many if not all of those instances a DLL is eventually loaded.  See the related list of loaded DLLs in my earlier post.
  • billmax's avatar
    billmax
    Turning off Sophos allows me to run QuartusPro, same as others have noted.
    However I still get 0xc0000142 DLL issues when trying to run a few  utilites: quartus_sign, quartus_worker, and quartus_encrypt. There may be others.
    Running with something as simple as -h command line option fails.
      KennyT_altera
      Hi Bill,
      We have contacted the sophos but require you to provide some information for futher support.
      Kindly check your email on this.
