Jens
7 months agoQuartus did not start
Hi, Since the switch to European Summer Time we cannot start Quartus Prime 2025 in Windows 11. Error Message: The application could not be started correctly (0xc0000142) What could be the reason ...
Jens
7 months agoHi billmax,
yes, we use Sophos. We will check the behavior without running Sophos when the admins allow us that.
KennyT_altera
7 months agoGood to know that both of you using Sophos, do let us know the result after you disable/uninstall it.
Also, can you list down all the software that is running behind the machine, if the above does not solve.
