Jens
7 months agoQuartus did not start
Hi, Since the switch to European Summer Time we cannot start Quartus Prime 2025 in Windows 11. Error Message: The application could not be started correctly (0xc0000142) What could be the reason ...
syoma
7 months agoHi Jens
We have just tested with Sophos Endpoint Agent settings and this is actually it. If you use Override Sophos Central Policy for up to 4 hours to troubleshoot and uncheck Malicious Behavior Detection ("Erkennung von schädlichem Verhalten") option in Runtime Protection - then Quartus is starting normally. So we are pretty sure it has something to do with it.
Could you please check on your side this again?
KennyT_altera
7 months agoThank you for your feedback, we will also investigate this and get back to you.
