16 years ago
Quartus compilation problem
Hi all,
I met a strange problem: when i use quartusii,a project first compiled need the Logic Elements is 13%,but then, i compiled again is 1%. :confused:
    --- Quote Start ---
    Hi all,
    --- Quote End ---
    Hi cherry,
    without any change ???? No design change, no settings changed ....
    Kind regards
    GPK
    this is the main program
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_arith.all;
    entity up3_board1 is
    port( datain_adc: IN STD_LOGIC_VECTOR(7 downto 0);--input from ADC
    clock: IN STD_LOGIC; -- Clock Input from Altera Board
    dataout_serial: BUFFER STD_LOGIC_VECTOR(7 downto 0));--8 bit data for trasmitting
    end up3_board1;
    architecture BEHAVIOR of up3_board1 is
    ------------------ COMPONENT UARTTransmitter------------------------------------------------
    component UARTTransmitter
    port ( txd_data: IN STD_LOGIC_VECTOR( 7 DOWNTO 0));
    end component;
    ------------component UARTTrasmitter------------------------------------------------------
    BEGIN
    PROCESS(clock,datain_adc)
    BEGIN
    if datain_adc="00000000"--data from ADC,not correct yet..
    then
    dataout_serial<="00000000"; -- pH 0.0,fake data
    txd_data<=dataout_serial;
    elsif datain_adc="00000001"
    then
    dataout_serial<="00000101";-- pH 0.5
    elsif datain_adc="00000010"
    then
    dataout_serial<="00010000"; -- pH 1.0
    elsif datain_adc="00000011"
    then
    dataout_serial<="00010101"; -- pH 1.5
    elsif datain_adc="00000100"
    then
    dataout_serial<="00100000";-- pH 2.0
    elsif datain_adc="00000101"
    then
    dataout_serial<="00100101"; -- pH 2.5
    elsif datain_adc="00000110"
    then
    dataout_serial<="00110000"; -- pH 3.0
    elsif datain_adc="00000111"
    then
    dataout_serial<="00110101"; -- pH 3.5
    elsif datain_adc="00001000"
    then
    dataout_serial<="01000000"; -- pH 4.0
    elsif datain_adc="00001001"
    then
    dataout_serial<="01000101"; -- pH 4.5
    elsif datain_adc="00001010"
    then
    dataout_serial<="01010000"; -- pH 5.0
    elsif datain_adc="00001011"
    then
    dataout_serial<="01010101"; -- pH 5.5
    elsif datain_adc="00001100"
    then
    dataout_serial<="01100000"; -- pH 6.0
    elsif datain_adc="00001101"
    then
    dataout_serial<="01100101"; -- pH 6.5
    elsif datain_adc="00001110"
    then
    dataout_serial<="01110000"; -- pH 7.0
    elsif datain_adc="00001111"
    then
    dataout_serial<="01110101"; -- pH 7.5
    elsif datain_adc="00010000"
    then
    dataout_serial<="10000000"; -- pH 8.0
    elsif datain_adc="00010001"
    then
    dataout_serial<="10000101"; -- pH 8.5
    elsif datain_adc="00010010"
    then
    dataout_serial<="10010000"; -- pH 9.0
    elsif datain_adc="00010011"
    then
    dataout_serial<="10010101"; -- pH 9.5
    elsif datain_adc="00010100"
    then
    dataout_serial<="10100000"; -- pH 10.0
    elsif datain_adc="00010101"
    then
    dataout_serial<="10100101"; -- pH 10.5
    elsif datain_adc="00010110"
    then
    dataout_serial<="10110000"; -- pH 11.0
    elsif datain_adc="00010111"
    then
    dataout_serial<="10110101"; -- pH 11.5
    elsif datain_adc="00011000"
    then
    dataout_serial<="11000000"; -- pH 12.0
    elsif datain_adc="00011001"
    then
    dataout_serial<="11000101"; -- pH 12.5
    elsif datain_adc="00011010"
    then
    dataout_serial<="11010000"; -- pH 13.0
    elsif datain_adc="00011011"
    then
    dataout_serial<="11010101"; -- pH 13.5
    elsif datain_adc="00011100"
    then
    dataout_serial_1<="11100000"; -- pH 14.0
    end if;
    end process;
    end BEHAVIOR;
    the program is when compilation of main program this error comes out
    "Error (10482): VHDL error at up3_board1.vhd(34): object "txd_data" is used but not declared"..i already add the component program file UARTTransmitter.vhdl to this main program
    any idea???
    --- Quote Start ---
    library ieee;
    end up3_board1;
    end component;
    BEGIN
    BEGIN
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    then
    end if;
    end process;
    end BEHAVIOR;
    any idea???
    --- Quote End ---
    I'm not a VHDL expert, but I think you have to define a signal called txd_data in your architecture.
    Kind regards
    GPK
    GPK
    Are you aware you have created a completly asynchronous design? there are no registers in this code.
    Also, you have not instantiated a UART Transmitter.
