16 years agothis is the main program
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity up3_board1 is port( datain_adc: IN STD_LOGIC_VECTOR(7 downto 0);--input from ADC clock: IN STD_LOGIC; -- Clock Input from Altera Board dataout_serial: BUFFER STD_LOGIC_VECTOR(7 downto 0));--8 bit data for trasmitting end up3_board1; architecture BEHAVIOR of up3_board1 is ------------------ COMPONENT UARTTransmitter------------------------------------------------ component UARTTransmitter port ( txd_data: IN STD_LOGIC_VECTOR( 7 DOWNTO 0)); end component; ------------component UARTTrasmitter------------------------------------------------------ BEGIN PROCESS(clock,datain_adc) BEGIN if datain_adc="00000000"--data from ADC,not correct yet.. then dataout_serial<="00000000"; -- pH 0.0,fake data txd_data<=dataout_serial; elsif datain_adc="00000001" then dataout_serial<="00000101";-- pH 0.5 txd_data<=dataout_serial; elsif datain_adc="00000010" then dataout_serial<="00010000"; -- pH 1.0 txd_data<=dataout_serial; elsif datain_adc="00000011" then dataout_serial<="00010101"; -- pH 1.5 txd_data<=dataout_serial; elsif datain_adc="00000100" then dataout_serial<="00100000";-- pH 2.0 txd_data<=dataout_serial; elsif datain_adc="00000101" then dataout_serial<="00100101"; -- pH 2.5 txd_data<=dataout_serial; elsif datain_adc="00000110" then dataout_serial<="00110000"; -- pH 3.0 txd_data<=dataout_serial; elsif datain_adc="00000111" then dataout_serial<="00110101"; -- pH 3.5 txd_data<=dataout_serial; elsif datain_adc="00001000" then dataout_serial<="01000000"; -- pH 4.0 txd_data<=dataout_serial; elsif datain_adc="00001001" then dataout_serial<="01000101"; -- pH 4.5 txd_data<=dataout_serial; elsif datain_adc="00001010" then dataout_serial<="01010000"; -- pH 5.0 txd_data<=dataout_serial; elsif datain_adc="00001011" then dataout_serial<="01010101"; -- pH 5.5 txd_data<=dataout_serial; elsif datain_adc="00001100" then dataout_serial<="01100000"; -- pH 6.0 txd_data<=dataout_serial; elsif datain_adc="00001101" then dataout_serial<="01100101"; -- pH 6.5 txd_data<=dataout_serial; elsif datain_adc="00001110" then dataout_serial<="01110000"; -- pH 7.0 txd_data<=dataout_serial; elsif datain_adc="00001111" then dataout_serial<="01110101"; -- pH 7.5 txd_data<=dataout_serial; elsif datain_adc="00010000" then dataout_serial<="10000000"; -- pH 8.0 txd_data<=dataout_serial; elsif datain_adc="00010001" then dataout_serial<="10000101"; -- pH 8.5 txd_data<=dataout_serial; elsif datain_adc="00010010" then dataout_serial<="10010000"; -- pH 9.0 txd_data<=dataout_serial; elsif datain_adc="00010011" then dataout_serial<="10010101"; -- pH 9.5 txd_data<=dataout_serial; elsif datain_adc="00010100" then dataout_serial<="10100000"; -- pH 10.0 txd_data<=dataout_serial; elsif datain_adc="00010101" then dataout_serial<="10100101"; -- pH 10.5 txd_data<=dataout_serial; elsif datain_adc="00010110" then dataout_serial<="10110000"; -- pH 11.0 txd_data<=dataout_serial; elsif datain_adc="00010111" then dataout_serial<="10110101"; -- pH 11.5 txd_data<=dataout_serial; elsif datain_adc="00011000" then dataout_serial<="11000000"; -- pH 12.0 txd_data<=dataout_serial; elsif datain_adc="00011001" then dataout_serial<="11000101"; -- pH 12.5 txd_data<=dataout_serial; elsif datain_adc="00011010" then dataout_serial<="11010000"; -- pH 13.0 txd_data<=dataout_serial; elsif datain_adc="00011011" then dataout_serial<="11010101"; -- pH 13.5 txd_data<=dataout_serial; elsif datain_adc="00011100" then dataout_serial_1<="11100000"; -- pH 14.0 txd_data<=dataout_serial; end if; end process; end BEHAVIOR; ------------------------------------------------------------------ the program is when compilation of main program this error comes out "Error (10482): VHDL error at up3_board1.vhd(34): object "txd_data" is used but not declared"..i already add the component program file UARTTransmitter.vhdl to this main program any idea???
