Ranjith21
2 years agoQuartus 23.3 transceiver toolkit fails to load using TCL
Hi, 1) I loaded the FPGA with the .rbf file 2) Next, I am trying to open the transceiver toolkit using TCL script. 3) When I click on "device_initialization.tcl", I get the following error: ...
- 2 years ago
Hi @Kshitij_Intel ,
I was able to fix this issue.
In "device_initialization" file, I replaced the string "AGFB027R24C2E2V" with the short version of itself i.e the string "AGFB027R24C"
This fixed the issue
Ranjith
Ranjith21
2 years agoHi @Kshitij_Intel,
Yes. I did modify the TCL script and added it to the path shown in screenshot
Also, attaching the TCL script here as a .txt file (unable to upload .tcl files here)
Still the same error exists:
Jan 17, 2024 1:28:43 PM com.altera.debug.core
SEVERE: java.lang.Exception: can't read "device_path": no such variable
while executing
"string length $device_path"
invoked from within
"if { [string length $device_path] == 0 } {
error "Specified $device_name device name, $device_die_name is not found. Please make sure the board is..."
Ranjith
