Ranjith21
2 years agoQuartus 23.3 transceiver toolkit fails to load using TCL
Hi, 1) I loaded the FPGA with the .rbf file 2) Next, I am trying to open the transceiver toolkit using TCL script. 3) When I click on "device_initialization.tcl", I get the following error: ...
- 2 years ago
Hi @Kshitij_Intel ,
I was able to fix this issue.
In "device_initialization" file, I replaced the string "AGFB027R24C2E2V" with the short version of itself i.e the string "AGFB027R24C"
This fixed the issue
Ranjith
Kshitij_Intel
2 years agoHi Ranjith,
As per user guide you need to update the script.
| Tcl File Name | Description |
device_initialization.tcl | You must update this script with which device is on the JTAG chain and what .sof is programmed into the device. When you run this script, it auto-loads the toolkit and automatically link the design information to the connected device. |
| Platform | Path |
| Windows | <drive>:\intelFPGA_pro\23.2\ip\altera\alt_xcvr\toolkit\ftile_transceiver_toolkit\scripts\ |
For more info please refer 7.5.1. Supported Transceiver Toolkit Scripts (intel.com)
Thank you,
Kshitij Goel
