Ranjith21
2 years agoQuartus 23.3 transceiver toolkit fails to load using TCL
Hi, 1) I loaded the FPGA with the .rbf file 2) Next, I am trying to open the transceiver toolkit using TCL script. 3) When I click on "device_initialization.tcl", I get the following error: ...
- 2 years ago
Hi @Kshitij_Intel ,
I was able to fix this issue.
In "device_initialization" file, I replaced the string "AGFB027R24C2E2V" with the short version of itself i.e the string "AGFB027R24C"
This fixed the issue
Ranjith
Ranjith21
2 years agoI updated to Q23.4. I added the variable IP_ROOTDIR to my system variable.
I have still the same error popping up:
Jan 11, 2024 2:43:13 PM com.altera.debug.core
INFO: Executing C:\Users\SysC\system_console\scripts\device_initialization.tcl
SEVERE: java.lang.Exception: can't read "device_path": no such variable
while executing
"string length $device_path"
invoked from within
"if { [string length $device_path] == 0 } {
error "Specified $device_name device name, $device_die_name is not found. Please make sure the board is..."
Please advise
Ranjith
