Ranjith21
2 years agoQuartus 23.3 transceiver toolkit fails to load using TCL
Hi, 1) I loaded the FPGA with the .rbf file 2) Next, I am trying to open the transceiver toolkit using TCL script. 3) When I click on "device_initialization.tcl", I get the following error: ...
- 2 years ago
Hi @Kshitij_Intel ,
I was able to fix this issue.
In "device_initialization" file, I replaced the string "AGFB027R24C2E2V" with the short version of itself i.e the string "AGFB027R24C"
This fixed the issue
Ranjith
Kshitij_Intel
2 years agoHi Ranjith,
Can you please check the Windows environment variable "IP_ROOTDIR" is set to the ip sub-directory in the Intel Quartus Prime Pro Edition software installation.
An example for the Windows* version is: IP_ROOTDIR = C:\intelFPGApro\21.1\ip
If the issue still exists, please share your design to replicate the issue at my end.
Thank you,
Kshitij Goel
