Quartus 22.4 crash "Internal Error: Sub-system: VRFX2, File: /quartus/synth/vrfx2/vrfx2_xmr.cpp"
When running synthesis on a design that synthesizes (and compiles) fine under Quartus Prime 19.2, I consistently get the following crash happening. It also crashes similarly under Quartus 23.1. Any ideas please?
Problem Details
Error:
Internal Error: Sub-system: VRFX2, File: /quartus/synth/vrfx2/vrfx2_xmr.cpp, Line: 254
ancestor_node
Stack Trace:
Quartus 0x8cf088: VRFX2_INST_GRAPH::dfs_paths(VRFX2_INST_NODE*, QTL_HASH_LITE<VRFX2_INST_NODE*, int, QTL_OPS<VRFX2_INST_NODE*, void> >*, QTL_HASH_LITE<VRFX2_INST_NODE*, VRFX2_INST_NODE*, QTL_OPS<VRFX2_INST_NODE*, void> >*, std::vector<Instance*, std::allocator<Instance*> >*) + 0x1ac (synth_vrfx2)
Quartus 0x8cf249: VRFX2_INST_GRAPH::find_common_ancestor_and_inst_paths(Netlist*, Netlist*, std::vector<Instance*, std::allocator<Instance*> >*, std::vector<Instance*, std::allocator<Instance*> >*) + 0x1bb (synth_vrfx2)
Quartus 0x8d202b: vrfx2_connect_global_net_to_port_or_portref(PortRef*, Port*, Net*, VRFX2_INST_GRAPH*, QTL_HASH_LITE<std::pair<Netlist*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, Port*, QTL_OPS<std::pair<Netlist*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, void> >*, QTL_HASH_LITE<std::pair<Netlist*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, Net*, QTL_OPS<std::pair<Netlist*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, void> >*) + 0x742 (synth_vrfx2)
Quartus 0x8d3d0f: vrfx2_process_global_net(Net*, VRFX2_INST_GRAPH*) + 0x304 (synth_vrfx2)
Quartus 0x8d4254: vrfx2_process_xmr_connections(BASEX_ELABORATE_INFO*, Array*, Netlist*) + 0x483 (synth_vrfx2)
Quartus 0x81665e: new_verific::VRFX2_EXTRACTOR::extract_hierarchy(char const*, std::vector<BASEX_ENTITY*, std::allocator<BASEX_ENTITY*> > const&, BASEX_ELABORATE_INFO*, bool, bool, bool, bool, bool) + 0x1264 (synth_vrfx2)
Quartus 0xfa337: QIS_RTL_STAGE::IMPL::elaborate_verific(QHD_PARTITION*, BASEX_ENTITY*, BASEX_ELAB_INFO_CORE&, std::vector<BASEX_ENTITY*, std::allocator<BASEX_ENTITY*> > const&) + 0x339 (synth_qis)
Quartus 0x10babd: QIS_RTL_STAGE::IMPL::elaborate(QHD_PARTITION&) + 0x2379 (synth_qis)
Quartus 0x10dcda: QIS_RTL_STAGE::elaborate(QHD_PARTITION&) + 0xc (synth_qis)
Quartus 0xa16eb: qis_elaborate + 0x246 (synth_qis)
Quartus 0x50fb7: TclNRRunCallbacks + 0x47 (tcl8.6)
Quartus 0x527df: TclEvalEx + 0x94f (tcl8.6)
Quartus 0xfa3a6: Tcl_FSEvalFileEx + 0x266 (tcl8.6)
Quartus 0xfa4be: Tcl_EvalFile + 0x2e (tcl8.6)
Quartus 0x2a8fc: qexe_evaluate_tcl_script(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x3de (comp_qexe)
Quartus 0x2dd73: qexe_do_tcl(QEXE_FRAMEWORK*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, bool, bool) + 0x4c2 (comp_qexe)
Quartus 0x2ee7b: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x66e (comp_qexe)
Quartus 0x6d1ec: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x9c (comp_qcu)
Quartus 0x6d638: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x343 (comp_qcu)
Quartus 0x409075: qsyn2_tcl_process_default_flow_option(ACF_VARIABLE_TYPE_ENUM, char const*) + 0x501 (quartus_syn)
Quartus 0x3421d: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0xba2 (comp_qexe)
Quartus 0x408ace: qsyn2_main(int, char const**) + 0x139 (quartus_syn)
Quartus 0x4e546: msg_main_thread(void*) + 0x10 (ccl_msg)
Quartus 0x4f764: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg)
Quartus 0x1f568: mem_thread_wrapper(void* (*)(void*), void*) + 0x98 (ccl_mem)
Quartus 0x10f3a: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err)
Quartus 0xb7f5: thr_thread_wrapper + 0x15 (ccl_thr)
Quartus 0x4f684: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xd8 (ccl_msg)
Quartus 0x40898e: main + 0x26 (quartus_syn)
System 0x21c87: __libc_start_main + 0xe7 (c)
Quartus 0x4088b9: _start + 0x29 (quartus_syn)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: Ubuntu 18.04.6
OS version: 18
Quartus Prime Information
Address bits: 64
Version: 22.4.0
Build: 94
Edition: Pro Edition
- SyafieqS
Do you mind attach the qar for me to replicate?
Need the design for further investigation.
Small design to replicate would be better.
- mpr90
Hi, I'm afraid I can't share the design as-is. Whilst it may be possible with some effort to reduce the design size and remove IP to allow sharing/reproduction, I'd like to know please if there are other things that I can do to gather forensics that may help to identify the culprit in this crash?
- SyafieqS
Internal error is normally a tool issue (most of it).
Thus, will be better if you can create small design replicating the error for further debugging.
- SyafieqS
Also, have you tried on 23.1 Pro?
Thus that resolve the issue?
Please let me know, otherwise I will need the small test case for investigation.
- mpr90
Running under Quartus 23.1 Pro had similar results: it also crashed.
It will take some time to get a test case together due to many other priorities, but I'll come back when I have one.
- SyafieqS
Let me know if there is any update from previous reply
- SyafieqS
Hello
Let me know if there is any update from your end.
- SyafieqS
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
