mpr90
3 years agoQuartus 22.4 crash "Internal Error: Sub-system: VRFX2, File: /quartus/synth/vrfx2/vrfx2_xmr.cpp"
When running synthesis on a design that synthesizes (and compiles) fine under Quartus Prime 19.2, I consistently get the following crash happening. It also crashes similarly under Quartus 23.1. Any i...
SyafieqS
3 years agoHi,
Do you mind attach the qar for me to replicate?
Need the design for further investigation.
Small design to replicate would be better.
- mpr903 years ago
Hi, I'm afraid I can't share the design as-is. Whilst it may be possible with some effort to reduce the design size and remove IP to allow sharing/reproduction, I'd like to know please if there are other things that I can do to gather forensics that may help to identify the culprit in this crash?
