mpr90
3 years agoQuartus 22.4 crash "Internal Error: Sub-system: VRFX2, File: /quartus/synth/vrfx2/vrfx2_xmr.cpp"
When running synthesis on a design that synthesizes (and compiles) fine under Quartus Prime 19.2, I consistently get the following crash happening. It also crashes similarly under Quartus 23.1. Any i...
SyafieqS
3 years agoInternal error is normally a tool issue (most of it).
Thus, will be better if you can create small design replicating the error for further debugging.
