Quartus 2024.2 GUI issues on Red Hat 9: "mprotect failed in ExecutableAllocator ..."
After starting quartus GUI, following message appears (~20 tiimes) on the command prompt:
mprotect failed in ExecutableAllocator::makeExecutable: Permission denied
Sometimes GUI also crashes, e.g. :
Problem Details Error: *** Fatal Error: Segment Violation: faulting address=0x10, PC=0x14d6216ae58c : 0x14d6216ae58c: db_rdb!RDB_FOLDER_OBJECT::find_object_by_path(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<ch Module: quartus Stack Trace: Err Handler 0x31437: ERR_UNWINDER_BACKTRACE::get_stack_trace(void const**, int, int, void*) + 0xed (ccl_err) Err Handler 0x8f044: msg_ie_get_call_stack(void*) + 0xc4 (ccl_msg) Err Handler 0x9258e: MSG_INTERNAL_ERROR::report_fatal(char const*, void*, bool) + 0x40 (ccl_msg) Err Handler 0x121c4: err_report_fatal_exception(char const*, void*, bool) + 0x63 (ccl_err) Err Handler 0x21fb5: err_sigaction_handler + 0x19a (ccl_err) System 0x3e6f0: (c) Quartus 0x12758c: RDB_FOLDER_OBJECT::find_object_by_path(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0xfc (db_rdb) Quartus 0x12762f: RDB_FOLDER_OBJECT::find_object_by_path(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x19f (db_rdb) Quartus 0x8ccbc: PJNQ_HIERARCHY_TREE_VIEW_RDB::get_resource_utilization_report_table_by_partition(RDB_REPORT*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x18c (prj_pjnq) Quartus 0x9bd59: PJNQ_HIERARCHY_TREE_VIEW_RDB::setup_hierarchy() + 0x1b9 (prj_pjnq) Quartus 0x9ced4: PJNQ_HIERARCHY_TREE_VIEW_RDB::on_rdb_updated() + 0x74 (prj_pjnq) Quartus 0x19dedf: void doActivate<false>(QObject*, int, void**) + 0x55f (Qt6Core) Quartus 0xbb364: PJNQ_NTFQ::ntfq_msg_rdb_updated(unsigned long, bool) + 0x34 (prj_pjnq) Quartus 0x628c: NTFQ_NOTIFY_TARGET::dispatch_notify_msg(NTFQ_NOTIFY_MAP const*, unsigned int, unsigned long, bool) + 0x972 (ccl_ntfq) Quartus 0x62c5: NTFQ_NOTIFY_TARGET::on_ntfq_notify(unsigned int, unsigned long, bool) + 0x2f (ccl_ntfq) Quartus 0x841f: NTFQ_NOTIFY_MGR::broadcast_notify(unsigned int, unsigned long) + 0x47 (ccl_ntfq) Quartus 0x86b1: ntfq_broadcast_notify(unsigned int, unsigned long) + 0x1e (ccl_ntfq) Quartus 0x6f7fd: FLOW_STATUS::refresh() + 0xe3 (sys_flow) Quartus 0x5dae5: flow_refresh_report + 0x8c (sys_flow) Quartus 0x4753b: TclInvokeStringCommand + 0x7b (tcl8.6) Quartus 0x4bb47: TclNRRunCallbacks + 0x67 (tcl8.6) Quartus 0x4cf29: TclEvalEx + 0x599 (tcl8.6) Quartus 0x4d646: Tcl_EvalEx + 0x16 (tcl8.6) Quartus 0x4d66d: Tcl_Eval + 0x1d (tcl8.6) Quartus 0x4d7fb: Tcl_GlobalEval + 0x2b (tcl8.6) Quartus 0x281f2: atcl_flush_queue(bool, bool) + 0x170 (ccl_atcl) Quartus 0xd99e7: AFCQ_APP::flush_tcl_queue() + 0x13 (gcl_afcq) Quartus 0x1e7c90: AFCQ_APP::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 0xe (gcl_afcq) Quartus 0x19dedf: void doActivate<false>(QObject*, int, void**) + 0x55f (Qt6Core) Quartus 0x1b0d4a: QTimer::timeout(QTimer::QPrivateSignal) + 0x3a (Qt6Core) Quartus 0x18fb75: QObject::event(QEvent*) + 0x205 (Qt6Core) Quartus 0x183102: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0x82 (Qt6Widgets) Quartus 0x18ea90: QApplication::notify(QObject*, QEvent*) + 0x2b0 (Qt6Widgets) Quartus 0x1404da: QCoreApplication::notifyInternal2(QObject*, QEvent*) + 0x12a (Qt6Core) Quartus 0x2e398e: QTimerInfoList::activateTimers() + 0x34e (Qt6Core) Quartus 0x2e0b98: QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0x588 (Qt6Core) Quartus 0x5e31e: QXcbUnixEventDispatcher::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0xe (Qt6XcbQpa) Quartus 0x84485: qui_call_app_process_event + 0x1e (sys_qui) Quartus 0xf5e4: thr_qt_process_events + 0x54 (ccl_thr) Quartus 0x161257: flow_process_events() + 0x9 (da_flng) Quartus 0x1662e5: FLNG::FLNG_LOCAL_SHELL_LAUNCHER::run_cmd(QString const&) + 0x453 (da_flng) Quartus 0x164e1e: FLNG::FLNG_LOCAL_SHELL_LAUNCHER::run_task(FLNG::FLNG_TASK*, bool, DA::BSC_NODE*) + 0x1ea (da_flng) Quartus 0x7d69a: FLNG::FLNG_TASK_MANAGER::run_task_with_qhd(FLNG::FLNG_FLOW*, FLNG::FLNG_TASK*, bool, DA::BSC_NODE*) + 0x11a (da_flng) Quartus 0x99ce3: FLNG::FLNG_TASK_MANAGER::run_task(FLNG::FLNG_FLOW*, FLNG::FLNG_TASK*, bool, DA::BSC_NODE*) + 0x673 (da_flng) Quartus 0x9ab71: FLNG::FLNG_TASK_MANAGER::worker_thread(FLNG::FLNG_FLOW*, unsigned int, bool) + 0x9c7 (da_flng) Quartus 0x9ea46: FLNG::FLNG_TASK_MANAGER::run_flow(FLNG::FLNG_FLOW*, QString const&, QString const&, bool, bool, bool, QString&) + 0x2120 (da_flng) Quartus 0x9feda: FLNG::FLNG_TASK_MANAGER::run_flow(FLNG::FLNG_OBJECT_ID const&, QString const&, QString const&, bool, bool, bool, QString&) + 0x72 (da_flng) Quartus 0xf177d: FLNG::FLNG_SERVICE::run_flow(FLNG::FLNG_OBJECT_ID const&, QString const&, QString const&, bool, bool, QString&) + 0x1dd (da_flng) Quartus 0x23456: flng_run_flow_command + 0x1b06 (da_flng_tcl) Quartus 0x4bb47: TclNRRunCallbacks + 0x67 (tcl8.6) Quartus 0x4cf29: TclEvalEx + 0x599 (tcl8.6) Quartus 0x4d646: Tcl_EvalEx + 0x16 (tcl8.6) Quartus 0x25444: atcl_tcl_eval(Tcl_Interp*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool) + 0x1c1 (ccl_atcl) Quartus 0x2b4e0: CONWQ_TCL_MANAGER::execute_tcl_str(QString const&, CONWQ_CONSOLE_TREE_VIEW*, QString*) + 0x1ee (prj_conwq) Quartus 0x1cfaf: CONWQ_CONSOLE::run_tcl_command(QString const&) + 0xc9 (prj_conwq) Quartus 0x1dac4: CONWQ_CONSOLE::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 0x4c (prj_conwq) Quartus 0x1533d6: QMetaMethodInvoker::invokeImpl(QMetaMethod, void*, Qt::ConnectionType, long long, void const* const*, char const* const*, QtPrivate::QMetaTypeInterface const* const*) + 0x876 (Qt6Core) Quartus 0x153f13: QMetaObject::invokeMethodImpl(QObject*, char const*, Qt::ConnectionType, long long, void const* const*, char const* const*, QtPrivate::QMetaTypeInterface const* const*) + 0x143 (Qt6Core) Quartus 0x854d6: qui_eval_tcl_command(QString const&, bool, bool) + 0x10d (sys_qui) Quartus 0x15f095: qui_flng_run_flow(FLNG::FLNG_OBJECT_ID const&, QString const&, QString const&, bool, QList<QString> const&, QList<QString> const&) + 0x4d1 (sys_qui) Quartus 0x15f9bc: QUI_PROCESSING_MENU::flng_run_flow(QString const&, QString const&, QString const&, bool) + 0x9a (sys_qui) Quartus 0x1763c8: QUI_PROCESSING_MENU::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 0x1ba8 (sys_qui) Quartus 0x18fc57: QObject::event(QEvent*) + 0x2e7 (Qt6Core) Quartus 0x1e0290: QWidget::event(QEvent*) + 0x2a0 (Qt6Widgets) Quartus 0x371a2b: QMenu::event(QEvent*) + 0x1cb (Qt6Widgets) Quartus 0x183102: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0x82 (Qt6Widgets) Quartus 0x18ea90: QApplication::notify(QObject*, QEvent*) + 0x2b0 (Qt6Widgets) Quartus 0x1404da: QCoreApplication::notifyInternal2(QObject*, QEvent*) + 0x12a (Qt6Core) Quartus 0x1439b5: QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 0x195 (Qt6Core) Quartus 0x2e065d: QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0x4d (Qt6Core) Quartus 0x5e31e: QXcbUnixEventDispatcher::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0xe (Qt6XcbQpa) Quartus 0x14b833: QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 0x193 (Qt6Core) Quartus 0x147e22: QCoreApplication::exec() + 0x92 (Qt6Core) Quartus 0x4025e4: qgq_main(int, char const**) + 0x6e (quartus) Quartus 0x44758: msg_main_thread(void*) + 0x10 (ccl_msg) Quartus 0x4521c: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg) Quartus 0x210ed: mem_thread_wrapper(void* (*)(void*), void*) + 0x9d (ccl_mem) Quartus 0xe2a8: err_thread_wrapper(void* (*)(void*End-trace Executable: quartus Comment: None System Information Platform: linux64 OS name: Red Hat Enterprise Linux OS version: 9 Quartus Prime Information Address bits: 64 Version: 24.2.0 Build: 40 Edition: Pro Edition
Any idea how to address this issue?
Ale Cefo
- KennyT_altera
Hi Ale,
When you mention ~20times, you mean you close and reopen 20times?
- KennyT_altera
Also, did you install all device? Or just selected devices?
- KennyT_altera
i manage to duplicate the error message that you are seeing,
But I was not able to see the internal/fatal error that you are seeing after close and open 20times.
Does the above error message hinder your project compilation?
Kenny Tan
- Ale_Cefo
Hi Kenny Tan,
In you reply I could not see the error message.
It seems that you've posted an image but it's not dislplayed on this web-page.
Could you please explain?In mean time, I've discovered that Quartus 24.2 Pro is supported only on RHEL9 <= 9.1, while I'm having RHEL9.4(Plow) image.
The GUI crash is most likely related to missing ncurses-compat-libs, since after providing it on LD_LIBRARY_PATH the project compilation finishes successfully.
The above failure is persitent.
I've tried using "export QV4_FORCE_INTERPRETER=0", but this only reduces the number of "mprotect failed ..." to a single message instead of 20.
Regards,Ale Cefo
- KennyT_altera
It seems that our backend system may be causing issues with viewing screenshots. In any case, I did not see the fatal error that you are experiencing.
Initially, I thought you were using version 9.0 based on the message "OS version: 9" mentioned in your fatal error. However, that does not appear to be the case.
Since you are not using our supported OS, you will need to downgrade the OS to Red Hat version 9.1 or lower. Installing on an unsupported OS can result in numerous issues, as we have not performed any validation on unsupported OS versions. Therefore, it is essential for you to choose a supported OS to avoid any potential issues in the future.
- Ale_Cefo
Hi Kenny Tan,
Downgrading the OS to Red Hat version 9.1 or lower, would require an exception, because our images are always upgraded to latest available (security related).
I'd appreciate if you can prvovide some inputs related to "mprotect failed in ExecutableAllocator::makeExecutable: Permission denied " , at least pointing out if it's related to Qt or similar packages,
otherwise we'll have to wait for 2024.x / 2025.x that can keep up with Enterprise Linux Life Cycle.
Ale Cefo
- KennyT_altera
Hi Ale,
Sorry, just want to clarify, can you provide me the exact steps you get the fatal error?
1) When you launch quartus, you get an error: mprotect failed in ExecutableAllocator::makeExecutable: Permission denied
2) Then you compile your design, you get a Fatal error?
If the error message is causing you to have a crash on Fatal error, I supposed from my side will get the similar situation as I am getting the same error in Redhat 9.1.
Beside the fatal error, any other problem that you face after getting the error above?
Kenny Tan
- Ale_Cefo
Hi Kenny Tan,
Yes, correct, the steps you've described are the ones that resulted in the GUI crash.
When I launch Quartus GUI, the Quartus Window opens, however on the CLI (terminal on RHEL9.4) it shows:
mprotect failed in ExecutableAllocator::makeExecutable: Permission deniedAfter providing ncurses-compat-libs on LD_LIBRARY_PATH the project compilation finishes successfully, thus the crash is gone, at least for this project.
Are you saying that message "mprotect failed in ExecutableAllocator::makeExecutable: Permission denied" also happens on RHEL9.1?
Thank you,
Ale Cefo
- KennyT_altera
Yes, I am experiencing this issue on Red Hat 9.1, but I am unable to replicate the crash on my end.
Could you please try using a different project to see if the crash persists? If the issue continues, please let us know.
Additionally, if possible, attach any small design .qar file that you have created on your end which replicates the issue. This will assist us in debugging the problem.
- KennyT_altera
Not sure if you have update on the question above?
- Ale_Cefo
I've tried Agilex7, Arria 10 and Stratix 10 projects in GUI mode and these finished successfully though with a workaround that uses LD_LIBRARY_PATH to point to ncurses-compat-libs.
"mprotect failed in ExecutableAllocator::makeExecutable: Permission denied" --> is perstient, any idea is this related to Qt?
I'm trying to get ncurses-compat-libs installed on this RHEL9 server by our Admins, but they are recluctant to do so, since ncurses-compat-libs isn't availble in default Red Hat Software Collections.
Is Altera going to address these issue with ncurses-compat-libs and "mprotect failed" in a future relase, do you know?
Ale Cefo
- KennyT_altera
To address the crash issue, we need to replicate it first. Could you please attach any simple design that you have run on your end? From my side, I have not been able to duplicate the crash. Another possibility is that the crash may only occur on Redhat 9.4, but not on Redhat 9.1, which we do not support yet. Thank you for your understanding and cooperation.
- KennyT_altera
Not sure if you have an update on the above? The other alternative is to wait until Quartus officially support Redhat 9.4 in the future release.
