Quartus 2024.2 GUI issues on Red Hat 9: "mprotect failed in ExecutableAllocator ..."
i manage to duplicate the error message that you are seeing,
But I was not able to see the internal/fatal error that you are seeing after close and open 20times.
Does the above error message hinder your project compilation?
Kenny Tan
Hi Kenny Tan,
In you reply I could not see the error message.
It seems that you've posted an image but it's not dislplayed on this web-page.
Could you please explain?
In mean time, I've discovered that Quartus 24.2 Pro is supported only on RHEL9 <= 9.1, while I'm having RHEL9.4(Plow) image.
The GUI crash is most likely related to missing ncurses-compat-libs, since after providing it on LD_LIBRARY_PATH the project compilation finishes successfully.
mprotect failed in ExecutableAllocator::makeExecutable: Permission denied
The above failure is persitent.
I've tried using "export QV4_FORCE_INTERPRETER=0", but this only reduces the number of "mprotect failed ..." to a single message instead of 20.
Ale Cefo
