KennyT_altera's avatar
KennyT_altera
2 months ago
Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SG
Hi Chandu sri,
We will continue the discussion here.
Issue
Chandu Sri is facing compilation errors in Quartus when working with the Arria 10 device (10AS057K2F40I1SG/10AS057K2F40I1HG) and HPS IP, both in Quartus Standard and Pro editions (20.1std, 24.1Std, 25.1.1pro).
  • Errors include unsupported device messages, out-of-range configuration values, and Tcl script issues when generating the HPS IP core.
  • The Arria 10 device is flagged as deprecated in the Standard version; IP core generation fails in Pro edition as well.
  • Example design generation is disabled for krpi_pcie.qsys; krpi_hps.qsys IP core creation fails with multiple errors.
Actions Taken
  • Device was changed from 10AS057K2F40I1SG to 10AS057K2F40I1HG, but errors persist.
  • Attempted manual recreation of the IP cores in 25.1.1pro instead of upgrading legacy designs.
  • Provided .qar file and detailed error logs to Intel support for further analysis.
Next Steps / Recommendations
  • Intel support (Kenny) has requested the .qar file for investigation.
  • Suggested complete deletion and manual re-creation of the problematic HPS IP in Platform Designer.
  • Discussion may continue on the Intel community forum if needed.
  • chandu_sri's avatar
    chandu_sri
    Hi kenny,
    could you try .qar files shared on Intel community forum. we are having urgent requirement of this upgrade.
    Chandu sri
  • As of Quartus Prime Standard Edition Version 22.1std.2, support for Arria 10 devices is deprecated in Quartus Prime Standard Edition.
    I would recommend to use Quartus Pro if plan to upgrade to a later Quartus version.
    I checked your design In Quartus Pro 25.1.1 and noticed there is a krpi_hps.qsys with generation error message stating that it need to be connected to a clock and reset sources.
    Could you confirm the design provided able to duplicate the error?  Where and how does the error occur?
    Is it during the Quartus compilation or the Platform Designer generation?
    More details is required.
    Thank you.
    Richard Tan
