KennyT_altera
9 months agoQuartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SG
Hi Chandu sri,
We will continue the discussion here.
Issue Chandu Sri is facing compilation errors in Quartus when working with the Arria 10 device (10AS057K2F40I1SG/10AS057K2F40I1HG) and HPS I...
RichardT_altera
9 months agoAs of Quartus Prime Standard Edition Version 22.1std.2, support for Arria 10 devices is deprecated in Quartus Prime Standard Edition.
I would recommend to use Quartus Pro if plan to upgrade to a later Quartus version.
I checked your design In Quartus Pro 25.1.1 and noticed there is a krpi_hps.qsys with generation error message stating that it need to be connected to a clock and reset sources.
Could you confirm the design provided able to duplicate the error? Where and how does the error occur?
Is it during the Quartus compilation or the Platform Designer generation?
More details is required.
Thank you.
Richard Tan
